About the Hydronics, Radiant & Water Heating category
This category is dedicated to all things related to liquid-based heating applications using hashrate heating systems. From residential radiant floors to industrial process heat, this is where the worlds of hydronic heating and liquid-cooled Bitcoin mining come together.
Use this space to discuss:
  • Hydronic system design: loop layouts, tube sizing, pump selection, valves, controls, and radiant zone management
  • Heat transfer integration: water heaters, boilers, hot tubs, pools, and industrial tanks heated with mining hardware
  • Hardware considerations: mining devices designed for or adapted to liquid cooling
  • Best practices: design principles from the hydronics industry paired with the realities of heat reuse from Bitcoin mining
  • Technical challenges: heat exchanger sizing, system efficiency, run lengths, and compatibility with existing infrastructure
This industry is not starting from scratch—hydronic and radiant heat systems are well understood, and now we’re introducing a new heat source into that equation. This category exists to bridge the gap between two industries and ensure that Bitcoin-powered liquid heating systems are designed properly, operate reliably, and unlock meaningful real-world value.
If you’re building, researching, or refining a system that heats liquid with hashrate—this is your category.
