This category is dedicated to all air-based heating systems powered by Bitcoin mining hardware—bringing together insights from the HVAC industry and the evolving hashrate heating ecosystem.
Use this space to explore:
- System design for furnaces, ductwork, and integrated blower systems
- Airflow management: fan sizing, CFM calculations, static pressure, dampers, and louvers
- Heat transfer setups: ducted heat exchangers, dry coolers, plenum designs, and recirculating air solutions
- Standalone units: space heaters, wall-mounted blowers, and other localized air-based appliances
- Integration into existing HVAC systems, including retrofits, zone control, and compatibility with thermostats and building controls
- Technical challenges: noise management, air balancing, condensation, reliability, and redundancy
- Best practices from the forced air and HVAC industry applied to Bitcoin heat reuse
Whether you’re adapting ASICs to blow hot air into a duct, engineering a hybrid air-liquid system, or fine-tuning airflow for efficiency—this is the place to share knowledge, ask questions, and refine designs.
