By default the stratum user field under settings has .bitaxe after the btc address where you want to be paid. When we replace the default address with our address, do we keep the .bitaxe at the end? If so whats the purpose?
Does this result in heat
Does what result in heat?
That’s your workername. You can append whatever you want after the bitcoin address with “.workername” and it will show in the pool as the name of the miner.
Much appreciated Tyler!
