Payouts Experiment: TIDES vs FPPS
I asked about a month ago if anyone had data on different payout structures (TIDES vs FPPS Payouts) but no one got back to me so about a week ago (2025.06.02) I started a payouts experiment at home with an S9 to build a dataset for myself on which pool payout type is best for home miners.
Some quick parameters:
Machine: 1x S9 running BraiinsOS
Why an S9?: It’s what I have on hand and I know a lot of plebs use them for space heaters.
Hashrate: Hashrate is split 50/50 using Braiins Pool Groups. Half to OCEAN with my own DATUM gateway and half to Braiins.
Why Braiins?: I’m aware there are cheaper FPPS pools out there, but Braiins has lightning payout which is essential for this little amount of hashrate.
Run time: I have a stupid time of use plan with my utility where electricity rates double or triple from 1300-1900 on weekdays so the miner is shut off then, on all other times (thanks Home Assistant automations).
Wattage: 800-1000w depending on how hot my garage is getting.
Is it the best experiment? Probably not but it’s what I came up with. I think it reflects my actual usage during the heating season.
Please let me know if you have any questions. I’ll post updates on this thread.
A week in and Braiins is crushing OCEAN.
Totals so far:
Braiins 1678 sats
OCEAN 792 sats
Some interesting notes:
OCEAN has had terrible luck finding blocks since I started this. I think at one point it went 85-ish hours between blocks. My OCEAN account has 1933 sats in the share window, so if OCEAN goes on a tear finding blocks it should catch up and/or surpass Braiins.
Initial takeaways:
If you’re mining in the short term, FPPS is seemingly more profitable. If you’re running long term (ie heating season), I expect to see OCEAN be more profitable but that’s dependent on how often they’re finding blocks which is dependent on the overall hashrate of the pool.
We have crossed the rubicon. I have finally provided enough shares for the entirety of the OCEAN share window.
Current stats (2025.06.13 8:57am MST):
Braiins 2233 sats
OCEAN 1357 sats (with 2307 sats estimated in the share window)
Braiins is still winning but the spread is tightening.
