The Space - Datum Gateway
If you’re mining to OCEAN, you should set up your own Datum Gateway. If, for whatever reason, you’re unable to, The Space has a Datum Gateway that you can use to save 1% on pool fees.
The Space Datum Server (pooled mining):
Pool url: stratum+tcp://datum.denver.space:3333
Username: [bitcoinaddress].[workername]
Password: x
If you want to donate hashrate to The Space, please use this address as your username with the pool url information above.
The Space OCEAN Mining Donation Address:
Username: bc1qlztjd50tvn6nxgle6f2kfrcsmxeh8nm6352rnl.[workername]
Password: x
